RCU Forums - View Single Post - 8UAP Flap Programming
Old 09-22-2003 | 01:53 PM
Krysta
Default RE: 8UAP Flap Programming
Hi Rusty,
You will need two Pmixes for this.
Go into your first Pmix, make the master Offset, the slave Flaps, then at your percentages, you will make this first mix +50%, with Link ON, switch C in the center position.
Next go into your next Pmix, again make the master Offset, the slave Flaps, and at the percentages you will make this on +100%, with Link ON, and now switch C in the down position.
I believe this is what you are looking for.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
