RE: Just got 502 in.Now What!
What Gene said. Sounds like you haven't built before so you may want to wait until your friend has some time to help you. A glass and foam core plane is a lot different then a stick built. I would sheet and glass the wing then paint. If you have never sheeted or glassed one before it can be a problem. Same when assembling the glass fuse. If you search here you will locate all the info needed but reading and doing can be a bit different.
