ORIGINAL: DAN AVILLA
The first thing is to exercise the connectors . About a week ago my slats on my F100 were choppy and loud. I pulled the connector and pushed it in and out mutable times . Their must have been corrosion on the signal wire. It fixed the problem . Also My buddy has had problems with 8711 going bad. Dan Avilla
+1
Have had this issue with even rudder servos on Bobcats and Kingcats, disconnecting and reconnecting the plugs a few times at each connector and that issue seems to go away. Interested to see what you fine as I have a Tam hornet to finish up.
