RCU Forums - View Single Post - Nitro fueling question
Old 06-11-2013 | 09:44 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Nitro fueling question
ORIGINAL: p3arljam
yes simple hand crank fuel pump just like on my other plane.
No that is your fuel pump that's not a fueling valve. OK lets get down to the nitty gritty, if your carburetor is flooded after filling the tank that badly then one of two things are happening Either - the carb is simply to low in relation to the tank and a syphon is started or you are simply fueling incorrectly for the plumbing and forcing fuel the wrong direction and into the carb.
You have not indicated how the tank is plumbed is it a two line system? or is it a three line system? is a Fueling Valve used (that is a popular device that stops fuel from being forced into the carb and directs it toward the fuel tanks. Not all airplanes a plumbed the same way and we have no way to know what your setup is unless you tell us.
John
