RCU Forums - View Single Post - Need your help............
Old 06-12-2013 | 03:10 AM
lookilook's Avatar
lookilook
Default RE: Need your help............
If you are using the ev5u-pro multifunction valve or similar and you run out of air surely there is a leak somewhere in your connections or gear/door cylinders. Use this link as info provided by Todd of Dreamworks and helped me and a lot of other people solving similar problems..good luck...http://www.rcuniverse.com/forum/m_99...tm.htm#9905381
