RE: Need your help............
If you have any blow by in your cylinders the valve will bleed the off that air.
Start by pinching off air lines one by one till leak stops. If they are leaking get yourself some BVM inline lube and shoot it into the cylinders...
Good luck, they are known for leaking.
