RCU Forums - View Single Post - Aeroshell 500 Prohibited
Old 06-12-2013 | 10:09 AM
Dr Honda's Avatar
Dr Honda
Default RE: Aeroshell 500 Prohibited
Hi Dirk,
Thanks for the info, and the pics.
From what I'm seeing... that's kind of typical when syth oils hit their burning point. (hard carbon, or a hard tar type substance) And let's face it... these oils were never meant to be burnt. They recirculate in a big engine.
So... either the other oils burn easier (ie cleaner) or... not at all. (curious)
Regardless... I guess Kingtech engine have a little more heat in the bearing tubes, over other engines. Not necessarily a bad thing, if you have an oil that works, and the pre-load system has enough movement to cover the growth.
I just got away from 500 myself, because of the toxic issues... but I want to be able to run one oil.
Since I have your attention... and not to take it of topic... but was the DTE doing the same thing??? Or was it just leaving flats in the balls?
