RE: BatShare with two receiver batteries - connections
Ok I use a bat share with no problem. The advantage of the batt share is if there is a problem with 1 battery it will isolate the bad battery from the system.
As far as your options on hooking it up to the receiver they are all 3 electrically the same. Inside the receiver all the reds are wired together and all the blacks are wired together. let me be clear the reds are seperate from the blacks. Anyway no matter which way you choose your hooking the batteries throught the batt share to the reciever in parallel. which keeps voltage the same but increases the current. Don't worry you not going to draw anymore current with 1 battery than you would with 2. But you have longer flying time between chargers
