RE: Reduced Landing Flap in Strong Wind
The purpose of flaps is to increase lift and drag. At lesser deflections, they mainly increase lift. As you increase flap deflection, lift increases but so does drag. Beyond a certain point, any additional deflection just adds more drag.
You want more lift for one purpose, to be able to fly slower, and thereby land at a slower speed, which means a shorter landing roll. Very important for jet airliners and jet fighters.
You want more drag for two reasons: First, to increase your angle of descent. This enables you to fly a steeper approach while maintaining a given airspeed. Second, to require more thrust on approach. This reduces spool-up time in the even of a missed approach.
So why would you want less flap in windy or gusty conditions? Actually you really don't, unless you are using a very high drag flap setting. Airbus A320's and Boeing 757's use the same flap setting no matter what. What they do change; however, is approach speed in gusty wind conditions. The same applies to model jets. In gusty wind conditions what you need is a higher approach speed to account for a sudden drop-off in headwind component. The only time you would use less flap for landing is if your normal landing flap is a high drag setting, like 40 degrees. In that situation, you might want to land with 30 degrees because you don't want any more drag than necessary in a go-around, and you don't want to have to wait for your flaps to go from 40 to 30 degrees. If you need to go around in a gusty situation, a lot of drag is the last thing you need. You want lift.
So to summarize, unless you normally land with a very high drag flap setting, you don't need to change your landing flap setting. Just carry a little more airspeed on final in case of a sudden drop-off in headwind component.
