RE: Adjusting Wing Incidence
The plane is trimmed and flies nose down. The plane is trimmed and flies nose up. Either case, what you're interested in doing is to get the plane to fly level, right.
So move the fuselage relative to the wing to level it out. The elevator trim will change unless you change it's incidence angle the same amount you change the wing incidence angle, of course.
