RCU Forums - View Single Post - Adjusting Wing Incidence
Old 06-13-2013 | 10:05 AM
karolh
Default RE: Adjusting Wing Incidence
If you need down trim for the model to fly straight and level then the wing has too much positive incidence, therefore you need to raise the trailing edge of the wing to reduce it. It will be pretty much a trial and error operation so do it in small increments. But considering you said that the model flies quite well if it was mine I would more than likely leave it alone for just a 1/16" out of line at the outer ends of the counter balance.
