ORIGINAL: Top_Gunn
however in the interest of terms..... "Spoilers" are used predominantly on sailplanes to reduce lift.
Yes. But on some planes, one spoiler can be raised while the other isn't, to induce roll. In full-scale aviation, that's called a "spoileron." In RC, people seem to use the term"spoileron" to refer to ailerons that can both be raised at the same time, to reduce lift. So the question is, are we using the same term - "spoileron" - to refer to two very different things, or is there another term for ailerons that can both be raised at once? It's not unheard of to use one term to refer to different things, and since nobody has offered anything different, maybe that's what's going on here.
I think you made that distinction clear earlier in the thread.
I think the real source of the ambiguity stems from whether the primary purpose of the "spoileron" is generating symmetrical lift, or asymmetrical lift. In the case of full scale aviation, spoilerons seem to be spoilers which only extend above the top of the wing. In RC, typically they refer to ailerons with a flap>mix program which can obviously deflect below or above (in the case of inverted flight) the wing. Maybe RC-specific spoilerons ought to be referred to as a negative flap mix, or reversed flap mix?
Respectfully,
Andy
