RCU Forums - View Single Post - question to carf rookie 2owners
Old 06-14-2013 | 06:24 PM
robersteam
Default RE: question to carf rookie 2owners
ORIGINAL: alasdair
I had a New Rookie a few years ago and I fitted the belly airbrake and also used the foreplanes as an airbrake.
The belly airbrake is adequate with idle throttle on my P-80. One tip though, bolt the control horn right through. Don't just glue it to the inner skin as in the instructions. Mine broke free by pulling a piece of inner skin away from the thin foam material in the middle of the laminate.
The canard airbrake is adequate on its own too, with idle throttle. No problems using it at all. It is not gradual however, it is on or off.
Both acting together is great. It gives very positive descent and allows a little throttle to be used which makes go-arounds easier. Just firewall the throttle, close the airbrake, flip the foreplane back to normal, retract the gear and ups she goes.
For an approach on idle throttle without any airbrake you need to take her a long long way downwind, come in really low and flat and expect a long float.
With both brakes operating, obstacle clearance on the approach is no longer a problem.
i knew it´s also an option,just two questions.does it have any pitch change? do you have fixed landing gear?
