The detail gun above (goirish) is a good one and I have had great results with it with 98.267% of my painting.
Currently using the combo in the links below and have had great results with these also. Gets a good bit of use in painting all sorts of things other than planes too...like the trim all around the house, inside and out
Got this setup because I'm using glow engines and KlassKote clear epoxy paint for my fuel proofer; the purple detail gun didn't care for the epoxy paint too much. For less than two Bills you can be fully set up with sprayer, compressor, hoses, adapters, filters and seperators.
If you are at all mechanically handy and wind up doing any automotive work you'll be really happy with the larger comressors ability to keep up with with any air tools that will shortly follow your purchase of the 8gal compressor.
http://www.harborfreight.com/touch-u...gun-66871.html
http://www.harborfreight.com/air-too...sor-67501.html
