RCU Forums - View Single Post - Setting up Canards and ailerons on a rafale?
Old 06-16-2013 | 07:03 PM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: Setting up Canards and ailerons on a rafale?
ORIGINAL: rduboc
Is anybody use Futaba 7c and Canards?, how can I configure to use cananrds with elevons please, I have a Eurofighter and I would like to mix the cannards to use only wit gears are down, thank you
Don't have the 7c, but you should be able to create a mix from the elevator function (master) to the canard channel (slave). Select the gear switch as the mix ON switch.
