ORIGINAL: number27
I have a Carf EURO and inject smoke at rear of pipe. Works well. Smoke appears about 500mm from end of exhaust. Using Sullivan smoke pump and diesel as fluid. 4mm brass tube on inside of pipe to 4mm stainless injector into exhaust.
Could you please advise how did you connect the 4mm brass tube to the stainless steel injector? (presume that they are connected inside the pipe) correct?
Thanks in advance,
Regards,
