RE: Futaba 14SG
You can assign any of the AUX functions to any channel on the 14SG but you cannot change their names to something more appropriate.Woodie’s suggestion should solve the brakes issue but, if you can’t get it to work, I am happy to help. To do so I would need a bit more clarification on what you are trying to achieve. I assume you wish to set up a mix from Elevator to an Auxiliary function (the brakes) which is only active when the Gear is lowered and which only takes effect when down elevator is applied. How do you want this Auxiliary function to respond? Does it travel from one end point to the other to deliver progressive braking or does it need to go to a set position to activate a simpler ON/OFF brake? Which switch do you use for your gear and in which of its positions is the Gear lowered?
