RCU Forums - View Single Post - Twine setup for super eagles turbines.
Old 06-17-2013 | 08:52 AM
JackD's Avatar
JackD
Default RE: Twine setup for super eagles turbines.
ORIGINAL: sysiek
Will try to install the switches on throttle ,y,cable and then try and restart if one turbine not start running.
I have a twin cheetah rafale. Did exactly like you mention, but instead of switches, I just have the connectors to the Y handy.
I start both of them at the same time (always with the data terminals), and if for any reason, one doesn't start (it never happens by the way), I just unplug/plug and start it again, while the other is running (or starting). Simpler than adding more switches
Regarding cross talking, in the rafale they are very close to each other and have never witnessed this problem (they are in separate bypasses though, so that might help).
So far i have about 50 flights with this setup, and the only flame outs I had were fuel system installation related. Once that was sorted out, it has been flawless
