RE: FEJ F-16 1/5.5 Gear NEEDED
Your best bet is to convert either set to electric. Even the new gear design will not work 100% of the time unless you give each gear its own air valves and tanks. You will come out cheaper converting your old set, unless you just need the the new gear. James is kinda out of the loop with family time contact Lowell.
