RE: Let's talk DX18 here!
Pete,
The easiest thing to do is to put a Y cable in the data port of the Rx and plug the TM1000 into it. Then, use a binding plug like normal in the other leg of the Y and do the following:
- power up the receiver with the Tx off - the bind lights on the Rx and the TM1000 should be flashing
- After everything is flashing/waiting to bind, then power up the Tx while holding your bind button and you should be good to go.
P.S. Just to make it more clear/explicit. If you use the Y cable, you don't need to worry about the pushing the button on the TM1000 while powering the Rx, the Y cable and bind plug do the same thing but just require less contortion.
If it still doesn't work, then you probably better talk directly with HH support.
