ORIGINAL: fw190
ORIGINAL: carrera mike
<span style="">TGIF! Able to work on the wings and installed the aileron and flaps, plus getting them set up for the servo and horn.</span>
You should glue your servo blocks grain wise perpendicular to the hatch plates and not parallel to prevent them from splitting from the plates.
thanks for the tip! I did realize that after I dry fit the servos.. I repositioned all the blocks now..
<span style="background-color: rgba(255, 255, 255, 0);">also thinking of screwing and strip of popsicle stick on the backside to tie both of those blocks over the servo.</span>
