RE: Unexpected flight characteristics
Get rid of the mix as that plane should not need one. Make sure it is straight. Take off is high power and slow speed; P factor taking over. High speed trim and takeoff trim will not be the same. You trim for flight and put up with for take off. If you have a TX that can do conditions you could make two trim settings but that is overkill on a 4*.
