"It's good to keep in mind that too much oil has never ruined an engine while too little will kill it
Larger engines can use less oil because cylinder bore area (where oil is needed) increases at a much slower rate than cylinder swept volume (which is what determines how much oil is drawn in)".
Yep!. But be prepared to replace/clean plugs as needed.
Watch out for Fox .59 as the only upper cylinder seal is the gasket on a flat surface- push it too hard and POOF!
