ORIGINAL: Hobbsy
Find your HS needle setting with the tank half empty and set it a couple of hundred rpm rich.
So your saying it can pull from a low tank.
This is 4*60 engines are upright, if I bolt the engine on bottom side of beam the carb is level with top.
Either I rebuild the fire wall or leave level just do'nt want problems if it's known not to work
Rich
