RE: Nominating Committee Minutes
To some, procedural protocol is apparently unimportant, but is the correct way to conduct business, in my opinion. It is also my opinion that the NC did a great job with a bad situation, on all counts.
JR
Let's let it all hang out. "Politically Correct" is NOT my forte. What IS my forte is GETTING THE JOB DONE or MISSION ACCOMPLISHMENT. Bombs on target or Passengers to destination-on-time was always the objective.
Was it politically correct how I finagled getting the final release of the frequencies from FCC? Not hardly as that could have been called bribery which I think may not be considered "procedural protocol", except it WORKS and that is NOT the only time I bought what I needed. Whatever gets the job done is what I go for.
When the road is blocked, if I am motivated to continue, I will find a suitable detour. Let the bureaucrats say nice words and play with each other. I'll be out getting work accomplished. I usually get to where I REALLY want to go. Like I said, if I REALLY WANT to go. I weigh each option and consider the potential net worth and risk. I do not jump off cliffs.
JR last year, you were one of a number that wrote a nomination for me to run for EVP. When I did not follow your instructions, you became very belligerent. Well JR, pass or fail, I do it MY way. That seems to be very difficult for you to handle. Your reactions are the epitome of the typical bureaucrat.
So, being on the EC is NOT going to be a party time for me. It will be hard work and will take me away from a number of things I much rather be doing. Yet I would do it for the sport of model aviation. I will use each and every method I can, if I determine that method will help build a fire under the EC to get things moving for more flying sites and less rules.
That determination will be made in D-VIII.
