RE: Assembly mistake
Do you feel lucky?
If so, just leave it as it is and fly the plane. Fix if things deteriorate.
Do you feel unlucky?
Take the least painful route - remove covering next to fin and whatever surface buts next to it - either top of fuse or stab - epoxy a triangle balsa fillet on each side, maybe 1/2" triangle or so. Put on some covering and fly the plane with no more worries. Forget about it forever more.
