RE: Top Flite Giant Scale Spitfire ARF
I'll try to get some posted this weekend.
Does anybody have a quick/easy way to extend the exhaust tubes? Mine extend just barely below the cowl and I'm hoping the exhaust heat doesn't have a negative affect on the cowl or the dummy scoop right behind them. The OD of the tubes are 22mm, so someting that will stay on in flight, but yet be easy enough to remove so you can take the cowl off. I need some ideas.
FB
