ORIGINAL: ahicks
Are you using the later ign. modules capable of handling voltage up to 8.4 volts? If not, what are you using for batteries to power the module? Are you using anything like a regulator or IBEC in the circuit?
Well the last iginitions i bougth from bob's hobby shop are just rcexl says 4.8 to 6volt.. bought them about um.. 1 yr ago i bought 3 of them.
I use a regular 4.8v battery back raging from 1000 - 1500mah connected to either a regular switch or a heavy duty switch before connecting to the ignitions red battery cable.
