RCU Forums - View Single Post - CM-6 Gas Engine problem
Old 06-20-2013 | 07:34 AM
karolh
Default RE: CM-6 Gas Engine problem
Absolutely no need to regulate a 4.8 volt battery. The fact that different brands of ignitions are all prone to failing and in the same way it is reasonable to assume that it is something that is common to your ignition circuitry that is causing the problem. Some pictures would be very helpful.
