RE: CM-6 Gas Engine problem
The regulator is a very good idea only if you use a higher voltage battery, but not with a 4.8V battery. If your problem is battery voltage related with a 4 cell battery, then too high a voltage in not an issue, but too low a voltage is very likely.
Pete
