RE: Installing and wicking hinges
There is an article by Minnflyer on installing CA hinges here on RCU. It's worth looking at. Make sure you use fresh thin CA and old CA can have problem wicking due to higher viscosity. You can insert small or medium T-pins along the hinge gap to maintain an accurate gap width when applying CA.
