RCU Forums - View Single Post - CM-6 Gas Engine problem
Old 06-20-2013 | 02:13 PM
Night Scream
Default RE: CM-6 Gas Engine problem
ORIGINAL: pe reivers
+1 with Raptureboy.
Rcexl ignitions are known to operate well up to 7V since day one! Maybe with shortened lifespan, but surely not 25 flights. I operate the old types on 2S LiFe battery to be sure of a strong spark. Others have done the same without ill effects. I use either NGK CM6 (used in Honda generators, not a Honda plug) or RCexl ICM6 iridium plugs. Both are good. The Iridium plug is slightly colder than NGK CM6.
Where can you get those iridium plugs from? First time I've heard of them
