I got the first test run in. Today was more about my muffler then anything else. The muffler was strong with no problems and the exits held up. I wanted to get some heat readings too. The exit plats reached 150 max. In the air they should be cooler. The engine ran flawless. Started right up and I kept it between 3000 and 6000 rpms. I am using a 24x10 so I am governing the rpms at 6000 for now. Next week I will run the 22x10x4 prop.
TB
http://youtu.be/GECly9byTyM
