RE: CMP BF109F BUILDING THREAD
She is actual 16.8 lbs full of fuel.
I am not sure. I tried to build light but I guess every little bit adds up. I do have a complete cockpit with a full bodied pilot. My control rods are golden rods by Sullivan. And I have two servos for the elevator. I'm using power HD servo for the rudder with a pull pull system. I had to add 4oz of lead to the tail to get the CG. 6 servos in the wings pluse 2 electric retract units. Emulation 26 gas engine. And a Dave Platt spinner. I put 2 micro servos in the engine compartment to control throttle and choke.
I will say that the kit parts add up to 13.5 lbs before glue, servos, etc. but even at that I thought I could keep it under 15 lbs. guess I was wrong.
It is no trainer but it still flys well. Take offs are smooth with no bad habits. When I fix the flaps I am sure the landings will be as easy, just a bit fast. She does slow down nicely after touchdown.
With the 26cc engine she is no rocket, but she flies very smoothly.<br type="_moz" />
