RCU Forums - View Single Post - DX8 RX IN A JET
Old 06-24-2013 | 02:18 AM
ron Sweeney
Default RE: DX8 RX IN A JET
Hi Greg, and jester, strange you should mention your radio, One of my pals had the same issue as you and the range was found to be suspect He has flown a lot since the set was returned with no more issues. I have flown the eight in several other models including big petrols. The logger was a bit high on counts in these a well. I have a faulty throttle trim so I will return the tx and see how it goes, Ron. p.s. my logger showed 'Hold' when the turbine quit at half throttle.
