I'm using the Hacker-Jetti Master 90 Comp with a Pletty Advance and am routinely using 4000 mah in the AMA Masters pattern which seems high to me. Did you have the timing monitor turned on in yours? Any idea what it does? I'm running a Pletty Advance with fixed endpoints, 24 degrees timing, new 5000mah Zippy Compacts, and so on. Most of the settings I'm using are comparable to the Spin 99 settings I'm seeing from Chad and others. The motor and controller are barely above ambient after I land. Everything is working great but the power consumption seems excessive for what I'm doing. I never hit or need full power throughout the sequence.
Verne Koester
ORIGINAL: cchariandy
4200maH for P and even more for F using TP G8 5000s, Falcon 21X14, 4750gm Xigris. I used linear for the Tx curve and have a nearly stratight line on the Tx. I will try 25 degrees for the timing and switch the timing monitor and setting thru RC off and see what I get.
