RE: F-89 Scorpion from Air-C-Race
The nose section is also removable. You can access your RCStuff via the cone which is held in place by magnets. It'll be important to mount as much of the RC /turbine electronics in the front to achieve the CGwithout the use of much lead. Ihope the job will be easier for me as I am most likely going for a single turbine configuration.
The nose junction als serves as nosegear mount. The whole nosecone plywood constructions is properly layered with carbon fibre.
