ORIGINAL: Kenrico
Hey guys,
I need to replace two stock jetcat Li-Pos used for P80se kero starts. Im thinking on some Thunder power batts but what would be the required C-rating? I bearly get two starts from the stock bat that came with the engines so im needing new ones.
Dreamworks has two on their website: a 3300MaH at 65C that they recommend for Kero Start, and they have a 4300 MaH at at 35c,
If 35C if is enough i would rather get that for the higher MaH and more starts on a charge.
Thanks! In advance!
I have been using a Thunder power 5000mah 2s 45c battery on my Jetcat P80se Kero start turbine for the last three years and i get up to 7 starts with out any issues before i have to recharge. I'm using the same set-up for my other two Jetcat P120sx's and i am able to get the same amount of starts on them.
