I finally found some documentation on the Timing Monitor. It allows you to turn the beeping sound in the motor on or off that happens during programing and when the controller initializes. Obviously, a good thing to leave on. I'll have to look elsewhere on why my mah consumption is higher than I think it should be.
Verne Koester
ORIGINAL: cchariandy
I had the ''setting thru RC'' ON. Although ''Timing monitor'' is in the Jeti Box Manual and flow chart I could not find it scrolling through the Jeti Box.
I have changed the stetting thru RC to OFF, my full throttle end point to fixed (1.9ms) and adjusted my ATV to match it, reduced the acceleration time and brake dead to be similar to Chads set up...those were the only significant differences.
I'll test it when it stops raining to see if I get any improvement.
Colin.
