RE: HK-450GT CCPM Alloy T-Rex compatible - Part IV
Don't know much about the v922 sound like the swash servos are not correct poss. when you apply power the swash is moving the wrong direction,
If you have a throttle hold turn it on and move the throttle pitch stick up the swash should move even to apply pos. pitch if it goes up in the front and down in the rear the pitch channel is reversed. also move the cyclic stick right left forwad back you should see the swash move in the correct direction if all is well poss you got bad servos or the gyro is defective. that all I can think of so far.
B. so it's time to soak in ????
Yep the weather here is sucky too high humidity hot and tstorms. I think i'll soak a couple of long necks.
Hugh
