RE: JetCat li-po bat C Rating
the higher the mah rating, the less C rating you need. mah times C rating is the max amps you can produce with a given battery. I use 5000 mah 25C batteries on kero start engines. that will deliver 125 amps! you are probably drawing 50 amps max on a kero start engine.
