RCU Forums - View Single Post - F-89 Scorpion from Air-C-Race
Old 06-26-2013 | 12:07 AM
Tuggs's Avatar
Tuggs
Default RE: F-89 Scorpion from Air-C-Race
Alright. A few words on the servo mounts in the tail section. The whole servo installation will only take a couple of minutes I think. The servo slides into the laser cut plywood support plate and is then inserted into the rudder /elevators. I will use Futaba standard sized servos and there is absolutely no trimming necessary. The servo has a very tight, slop-free fit and the only work left to do is to cut out the slot for the servo arm. Pretty mean design, I think.
ID:	1895208   Click image for larger version
ID:	1895209   Click image for larger version
