RCU Forums - View Single Post - T - max reverse problems
Old 09-23-2003 | 01:13 AM
Dlock
Default RE: T - max reverse problems
Be sure your idle is not set to high, like previously stated. Also you can move the collars that are on each side of the serve horn on the fwd/rvs linkage in some. Basically move them in towards the middle. This will give you more tension in those springs.....
