RCU Forums - View Single Post - JAE
Thread: JAE
Old 06-26-2013 | 07:52 AM
Ron Olson's Avatar
Ron Olson
Default RE: JAE
If you're still using the stock heat-sink head you can remove most of the fins as you don't need them. You'll not only reduce weight, have less hanging out in the open air but will allow the engine to build up heat for better performance. With the engine so close to the cool air coming off the water it doesn't need those big heat-sinks.
Post some shots of your boat when you get a chance to.
