RE: gas throttle set up question
I knew that was coming (ez link part). Those are trusted links (meaning veterans) & very reliable. In any case, throttle is now pull to open. if it comes off it will dead stick. Then, putting ball links both sides will require either full threaded rods whiich I don't have or nyrod linkage which I ant comfortable with. This setup is fairly well tested
Ameyam
