RCU Forums - View Single Post - Throttle problem
Old 06-28-2013 | 02:28 PM
kcwood
Default Throttle problem
<span style="font-size: medium">Hi
I am newbe to the 6 channel computer radio system
Ireceived my new Tactic TTX650 &amp; 6 channel receivers and I am trying to setup a Flyzone Cessna 182 Skylane RX-R (5 channel required)
</span><u><span style="font-size: medium">The Cessna has a Tactic ESC (TACM6610)
</span>
</u><span style="font-size: medium">I tried the throttle channel 3 in normaltheesc sounded startup *** ** * ** but no throttle, alsomoved throttle up to max and waiting 5 secondsthen loweringno sounds at both ends, then tried with channel 3 reversed ESC sounds alert tone with continous beeping * * * * * * * * *
The ESC recognize the throttle and works finein a Starmax 4 channel System but <u>I want the 5th Channel setup to use for the flaps
Is the problem with the ESC? , ESCthrottle calibration has not setup
</u>I setup 3 other planes an FMS BF-109, FW-190 &amp; Aerosky DHC Beaver on the Tactic TTX650, I did have to reverse the throttle channel on each &amp; I reset the receiver all work fine.
How do I set up or reset the throttle calibration on TACM6610 ESC ?or do I have to buy another ESC?
Thank You,
Ken</span>
