Sig Kadet Lt-40 Problem
I am assuming that the torque rods were already installed as part of the ARF. Probably what has happened is that whomever assembled it got some glue on the the torque rod, and that is causing the binding. You might try dripping a very small amount of acetone down the tube and work it back and forth. This suggestion is given assuming you do not have any binding due to interferance of any sort.
Vince
