RE: Spektrum DX6i no longer working - Guidance Needed
I apologize that my post came across as 'facetious'. I should not have tried to help at all, I guess. I wouldn't ask someone to take their time writing out instructions to something already in my hands. And I was surprised I didn't get an answer like 'Yes, I know about that already', and then we would look for the source of the problem elsewhere. That's where the 'Really?' in my post came from.
1. Turn on your tx.
2. Press the roller like a button.
3. It should be on the 'Adjust List'. If it says 'Setup List', roll the roller to scroll all the way down to where it says 'Adjust List' and press the roller again.
4. When you're on the Adjust List, roll the roller to highlight the first item, Model Select.
5. Roll the roller to the model number you want to select and press it. It will now go to that selected model.
You must bind to each different rx on a different model memory.
