RCU Forums - View Single Post - CA QUESTION......HELP
Old 09-23-2003 | 08:42 AM
Lightfoot
Default RE: CA QUESTION......HELP
I know this does not answer the question that you asked but if this is your first kit, I would recommend that you use an aliphatic resin such as Titebond II to build this kit. It allows time to correct mistakes before the glue sets but the strength is equal to or greater than that of CA. Of course it takes longer to set up and will result in a longer building time but it could reduce some major headaches in the long run.
