RCU Forums - View Single Post - Building the original Byron P-51 Mustang
Old 07-01-2013 | 05:01 PM
  #65
invertmast's Avatar
invertmast
My Feedback: (23)
Default RE: Building the original Byron P-51 Mustang
Jeff,
I believe the engine is a Quadra 42. As far as the elevator linkage, i would just build up a new one. I dont like relying on a set screw sittin on a small flat to hold, especially on something as important as ye elevator.
As far as glassing foam. Taking some lightweight dry spackle and mixing some water in it to make a runny mixture, then spreading that over the foam helps seal up some of the voids on the surface of the foam so it absorbs less resin.
